Please can anyone help disgnose a fault with my BWM R1100RS 1994
Symptoms are:
Intermittent fault when opening the throttle from closed position (ie after changing gear). There is a short time delay before there is a distinct "kick" from the engine almost as if one of the butterflies in a "carburretor" is springing open.
Appologies if i am using incorrect terminology. I am aware that it is fuel injected. The throttle cables are free and I am pretty sure the butterflies are opening smoothly and in unison. I have run injector cleaner through it. I have cleaned the tank out. It has a new fuel filter & air filter. BMW approved dealer was unable to diagnose the problem despite having it in to check over twice. They tell me the valve & ignition timing are correct.
Can anyone assist as other than this irritating (and worst of all intermittent) fault it is a wonderfull beast.
Thank you
Symptoms are:
Thank you
